Pulsating Scratching Sound (brakes?) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2008, 07:20 AM   #1 (permalink)
View fernden's Photo Gallery
I have a 1990 Camry. For the first couple of minutes that I drive it after it's sat for a while (like, for example, overnight), there's a pulsating scratching sound that goes away when I push the brake. After about 2 minutes, it stops completely? Obviously it's something brake-related, right? Any guesses at what it could be?
fernden is offline   Reply With Quote
Old 08-11-2008, 01:03 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If it is coming from the back brakes it kind of sounds like a shoe retraction spring has broken.
Kep
Old 08-12-2008, 11:52 AM   #3 (permalink)
View MARIO2007's Photo Gallery
I would also check and see that your bearings are not shot either.If the wheel wobbles because of a bad bearing up front it could be scraping against the caliper and smooth out on its own as you start to drive if its not badly worn , but something like that only gets worse. I would jack up the car and check for wheel wobble to be on the safe side .
MARIO2007 is offline   Reply With Quote
