What ia a bolt-in replacement for a 2S-ECL
Just had the head redone on the wife's '86 Camry - she overheated the engine and cracked the old head in two - luckily the rings survived intact. So now, because of the better compression, the engine has a pronounced knock on start up when cold that seems to go away as the engine heats up. From reading another thread on the board I'm going to change to 10-40w high mileage oil from the 20-50w I've been using as a temporary fix and get the engine to last as long as possible.
However, when the thing eventually dies, I will most likely replace the engine since the car is absolutely mint. I understand 2SE engines are sort of hard to find, and I have a good '89 4AFE, wiring harness and computer out in the garage. Will the 4AFE bolt up to the 2SE auto tranny? IF not, will the 4AFE and it's automatic tranny bolt into the '86?
BTW: what typically causes the knock in a situation like this? Rod bearings? main bearings? piston pins? And is it easily fixable on a weekend or two?
Thanks!
