Unplugging the Air flow meter also cuts the power to the gas pump; during the engine cranking, the power is fed to the fuel pump from starting circuit [as long as the key in START position}; as the engine start the switch in AFM takes over.
Two things needed to be done: short the T and E1 terminal in the diag box and look for codes 12, 13, 14.
If none present, check for the 12V at ign connector black/orange wire on the distributor.
IMPORTANT: as engine cranking when no spark, DOES tachometer needle jumps from 0. If so the problem is in the secondary ign circuit.
