Suddenly no power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2008, 06:19 PM   #1 (permalink)
View JS Gryphon's Photo Gallery
Suddenly no power
Wife's 87 Camry suddely has no power, nothing not even a courtesy light. Went to work one day, next morning absolutely nothing. Battery checks out good, new starter, everything seems to be OK, just no electricity.Any and all ideas would be appreciated. Also need source for inside fuse diagram as her drivers side fuse door is missing and the passenger door has lost the diagram.
The little customers book shows nothing as to which fuse is for what.
JS Gryphon is offline   Reply With Quote
Old 09-15-2008, 10:32 PM   #2 (permalink)
View drugal's Photo Gallery
Did you check the three main fuses at the positive battery terminal? I would start there.
Are the battery terminals and leads free of corrosion?
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 09-16-2008, 12:15 AM   #3 (permalink)
bkbajan's Avatar
View bkbajan's Photo Gallery
yea..checkur fusible links first
bkbajan is offline   Reply With Quote
Old 09-16-2008, 10:15 AM   #4 (permalink)
Yes, I have the ones that you can actually see the copper links the other one is black and I don't know of any way to tell. The battery is in perfect shape. I still need to find info on the inside fuses as I stated in my first message.
Old 09-16-2008, 09:42 PM   #5 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation Just check ALL fuses And alternator
After you know that all fuses are good (and I think they are)
Make sure the fusable links are not seperated. A gap means that the fuses is blown!
The last time my Camry did this I found the Main wire going to the Alternator was all corroded and needed cleaning.
I replaced the Alternator and cleaned the main (largest) wire connection going to it.
NO MORE PROBS SINCE!
malayan is offline   Reply With Quote
Old 09-16-2008, 09:46 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
check the grounds
Old 09-17-2008, 07:00 PM   #7 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
If anything is loose tighten it check all the fuses under the hood one of those main ones are probably blown and now the car has nothing.
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
