3 attempts tbefore start..ONLY WHEN COLD THOUGH?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2008, 01:35 PM   #1 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation 3 attempts tbefore start..ONLY WHEN COLD THOUGH??
My 87 2.0 is hard to start but only when the engine is cold.
After warm up ...always starts right up!
or
Help find proper forum..
Thanks in Advance for the nice website!!!!!!
malayan is offline   Reply With Quote
Old 09-19-2008, 06:07 PM   #2 (permalink)
Gameroom cash: $302555
Check the cold start time switch when the engine is cold. It's the sensor under the brown plastic connector, on the water port on the right side of the cylinder head, as you are standing in front of the engine. You need to remove the connector and then you will need a digital volt/ohmeter and the specs from any manual. These commonly go out of range after many years and miles of service and do not send the proper signal to the computer. The computer then doesn't know the engine is cold, and will not richen up the fuel mixture to facilitate a cold start. Check it out first, as these are a dealer only part and run about $100.
Mike
Old 09-19-2008, 09:05 PM   #3 (permalink)
malayan's Avatar
2nd Generation Thanks
Ok, thought it was the fuel pump as I have to try it twice , then on he third time it starts. Idle goe high then slowly comes down.
I love this website
Old 09-19-2008, 09:26 PM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Sometimes you'll get a normal reading from the cold start timing switch, but the cold start injector is faulty (happened to me last winter). The actual cold start injector is located on the intake plenum, and it has both a wire and a steel fuel line running to it. It drips the fuel into the intake when instructed by the timing switch to do so.
For either part, you can probably get 'em at a u-pull-it wrecker for pocket change.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 09-20-2008, 11:21 AM   #5 (permalink)
malayan's Avatar
2nd Generation Thank You TBAY
I will be checking both the switch and the cold start injector today.
You guys are sooo helpful!
After we spokke the last time I took the car to Washington State DEQ.
It passed ALL high rpm tests except the low idle emmisions too great.
went home and found the vaccum line going to the power steering pump was off (noticed a difference in idle when I plugged it back in) .
still not a totally smooth idel. ( I am gonna check all four injectors too). I could have swore I could hear them clicking. Is this normal.
Hope it pass this next time.
Old 09-20-2008, 11:22 AM   #6 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
+1 on the cold start injector. I had a leaky one on my Camry, and it would actually flood the engine when sitting for a long time (i.e. "cold" starts). Only mine would always start on the 2nd try right away, and always started easily if it didn't sit too long after running.
Do you get a puff of smoke out the back when it starts?
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 09-20-2008, 02:04 PM   #7 (permalink)
"I could have swore I could hear them clicking. Is this normal."
Yes, it is normal for fuel injectors to make a slight ticking sound.
Mike
Old 09-20-2008, 07:25 PM   #8 (permalink)
malayan's Avatar
2nd Generation Yes you are right
Yes! it did smoke after starting before but it seems to be getting better the more I drive it (it sat in the garage for a couple months before I put a crate moter in it). 100miles on it so far!
I swapped out the AC compressor today and fixed the Drivers Auto seatbelt(broken wire going from the door to the fuse box area).
Thanks again you guys. Tomorrow I will install the 4 injectors I got from a 40k motor before I run i through the DEQ again.
Time for a beer. Just got home... Here is a pic of just one of my GEN2 Camry's.
Old 09-20-2008, 08:05 PM   #9 (permalink)
HomeGrown's Avatar
Don't mind if I do! Corona, please!
How many Gen 2's do you have??
Old 09-30-2008, 09:17 PM   #10 (permalink)
malayan's Avatar
2nd Generation It Passed Deq Emissio(n Test
Failed DEQ and was not running smooth . the idle bounced around about 200rpm.
It passed Washington State DEQ test (very picky state).
After I unplugged the throttle sensor and retarded the timing. Runs smooth.
Passed with flying colors this time.
weird. casuse I plugged the TS back in and now it is smooth still OK
Maybe it was the timing all along.
hope this helps someone.
Old 10-05-2008, 07:33 PM   #11 (permalink)
the gen 2
blkdmnrcing's Avatar
View blkdmnrcing's Photo Gallery
i can atest to the cold start injector. i have swapped out the head for a JDM Head and it eliminated my cold start injector. now takes two to three tries in the winter time to get it started.
89 Camry I4 5-Speed - JDM Head, Turbo'd! Now needs Exhaust and Tune!!
93 Paseo I4 Automatic - Daily Driver
look out, ed wants to drop kick spiderman!!
blkdmnrcing is offline   Reply With Quote
