Location of wiper delay controller? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2008, 08:16 PM   #1 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Anyone know where the wiper delay controller is at on these cars? I'm thinking about taking the one out of my '88 and putting it in my Tacoma.
I don't mind the manual crank windows & manual locks, but the thing that I really miss the most is the delay wipers (my truck is VERY stripped).
If I can remove the delay circuit without losing the functionality of the wipers, I'm on it.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 09-20-2008, 08:23 PM   #2 (permalink)
just a nobody
I think you will need both the wiper motor and the switch assembly, look at the wiring diagram.
N.E.O.
Old 09-20-2008, 09:24 PM   #3 (permalink)
HomeGrown's Avatar
Shouldn't need the motor, unless it's got the delay circuit imbedded in it, which is not likely.
Good thought on the wiring diagram.
Old 09-25-2008, 10:09 PM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Actually, I think the Camrys have the same set-up as the Corollas of the same vintage--and the delay is actually built right in to the wiper motor assembly. So is the "return" function (that allows the arms to return even if you turn the wiper off in mid-arc).
HomeGrown, update me on this one when you find-out for sure. I'm curious, considering my gen2 is so old and so used. It'll probably start acting-up any time now.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 02-03-2009, 10:34 PM   #5 (permalink)
Dreaming of AllTrac
View Time Traveller's Photo Gallery
I too, am wondering where the delay and return functions are located. My Gen2 Camry IS acting up... No return or delay. I've read elsewhere that it's located in the combination switch, but I don't want to sink the money into a switch without knowing! Did the wiring diagram indicate the location of this circuitry?
Time Traveller is offline   Reply With Quote
Old 02-03-2009, 11:23 PM   #6 (permalink)
View nuron's Photo Gallery
http://camrystuff.com/manuals/Gen2/90_EWD.pdf
Page 98. Looks like the relay is in the switch, although the motor might need the connections to it also. I'm wondering if I can take the ES250 stalk assembly to get the selectable interval system like the newer cars.
nuron is offline   Reply With Quote
Old 02-04-2009, 02:22 AM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
LE from at least '89+ also has the variable intermitant wipers.
-Charlie
Old 02-04-2009, 03:00 AM   #8 (permalink)
Kickass!
Old 02-04-2009, 05:03 AM   #9 (permalink)
1990 Camry Base
View chubcobear's Photo Gallery
Relay function seems not to be in motor
1990 Camry motor was replaced on mine and did not solve the delay and reset problems. The delay/reset function must be in the switch or wiring, not the motor. However, the new (rebuilt) motor is a bit slower and less violent at full speed than the original one......which is better. T.C. Bear
chubcobear is offline   Reply With Quote
