Replacing needles in dash? + other problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2008, 05:44 AM   #1 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Australia Replacing needles in dash? + other problem
Was wondering, how would i go about changing the needles in the dashboard? Nearly all my needles are warped. Is it as simple as yanking it out or would i need a whole new dash? Also, i think the temp gauge is wrong. I got this car 2nd hand and the previous owner said that the temp. gauge is incorrect. When i start it up, it shoots all the way up to high and will drop back down to normal temps and raise again, needles goes back and forth and doesn't really settle. What could be going on? Faulty thermostat? Loose connection somewhere? Any help is appreciated.
Jimnist is offline   Reply With Quote
Old 09-22-2008, 06:57 AM   #2 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Yeah, pretty much you just carefully pull them off and push the new ones on. I had to do this when I swapped in a tach cluster on my '91. No problem, just be extra careful to make sure they're aligned properly.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 09-22-2008, 07:40 AM   #3 (permalink)
セクシーの定義
Did you get new needles from Toyota or did you get them from wreckers?
Old 09-22-2008, 06:57 PM   #4 (permalink)
HomeGrown's Avatar
I had to remove them during a tach cluster install, in order to remove & swap faceplates. I got an older tach cluster, which had different mounting holes than my '91. Hence, the need to remove needles & swap faceplates.
