Did y'all miss me? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2008, 12:35 PM   #1 (permalink)
Terrible mechanic
View ThomasToTots's Photo Gallery
Did y'all miss me?
Its been a while but Im picking the rebuilding project back up on the 89 camry wagon. I started and first thing I did was crush a rod bearing. so new bearings are in the mail. cyclenders are honed. Rings are set. oem head gasket is ready. WISH ME LUCK. or come help which ever
1995 mazda mx-3 1.6l (Cracked head now at pick n pull)
1987 Camry wagon 2.0 (Might live)
1991 mitsubishi 3000gt vr4 (hopeless case but I love her)
1995 Chysler Town and country 201k
ThomasToTots is offline   Reply With Quote
Old 09-25-2008, 01:20 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Try to post pictures as many as possible so someone can spot the problem; and inspect all electrical connectors before attaching wiring!
Doctor J is offline   Reply With Quote
Old 09-30-2008, 02:08 PM   #3 (permalink)
Terrible mechanic
Well bearings arived today and I put 2/4 the pistons in place. I would have put all 4 in today but pistons 2 & 4 had either a broken compression ring (2nd piston 2nd ring) or a missing ring (4th piston 1st compression ring) Now I know I just lost the piston ring on #4. not sure how #2 broke, anybody know where I can buy 1 cyclender of pistons rings? (rest are new already) I dont want to pay 50 bucks for 2 rings. any suggestions?
Old 09-30-2008, 04:29 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
dealer
Old 09-30-2008, 05:24 PM   #5 (permalink)
Terrible mechanic
I tried them and they told me a new set will cost 154 dollars. and I can only buy them as a set.
Old 10-01-2008, 10:29 AM   #6 (permalink)
Doctor J's Avatar
Just wondering why so many rings are breaking?
Did you remove ridge from the top of each cylinder bore?
Have you used ring compressor or at least .004 thick steel stock to wrap around the piston[and tape over the wrap]
Old 10-01-2008, 05:42 PM   #7 (permalink)
Terrible mechanic
Only 1 ring has broken inside the engine. total Ive had to replace 4 rings. 2 rings snaped while I was installing them. 1 got lost after I took it off to verify the clearance and the 4th had a nice chunk missing out of it on the number 2 cyclender Ill show you the missing chunk once I can post pictures again
Old 10-06-2008, 04:36 PM   #8 (permalink)
Terrible mechanic
progress : rings are on , new bearings are in, pistons are in, head is cleaned really well and new oem headgasket is on. bolts are star torqed to spec (36 ft lbs) intake cam is stalled and sealed (the front seal) tightened progressively 2,4,3,1 order. and I stoped there for the day. So far its all going smoothly. Tommarow I can recheck torque on rod cap bolts and then put strainer and billow on and put the pan on. Not looking forward to all those bolts.
Old 10-08-2008, 10:13 PM   #9 (permalink)
Terrible mechanic
thomas might have just gotten a death sentance. Somebody stole My cat. So now I have to decide is another 300+ dollars into the car is worth it. Frankly I like the car but I have a full plate. Anybody want a good engine with new pistons rings new head gasket new bearings new oil pump new water pump, and a very clean body for like 800 bucks? tranny ran nicely.
Old 10-09-2008, 01:20 AM   #10 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Can you not get a used cat cheaply at a wrecker? Maybe if you unbolt the manifold and cut the downpipe (thereby removing it all as one unit), you can get away with paying only for the manifold at a u-pick parts yard. The wrecker I used to work at had no idea the cats on the 3s and 5s engines were located at the manifold...only after I pointed it out did they start removing them!
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 10-09-2008, 08:38 AM   #11 (permalink)
Doctor J's Avatar
California wreckers do not allow to buy the cats from them.
It is not a good idea to work on the car in front of nasty neighbors.
Old 10-09-2008, 10:14 AM   #12 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
put a 3sge manifold and pipe on it and put a cat under the car
Old 10-09-2008, 10:25 AM   #13 (permalink)
Doctor J's Avatar
This may be considered as "tampered with" according to California smog regulations
Old 10-12-2008, 07:41 PM   #14 (permalink)
Bullitprooph
Wow, Cali really does have the strictest smog rules outside of Japan! How frequently do you have to re-smog a California car? Every year?
Old 10-12-2008, 08:02 PM   #15 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
Utah county and others here smog the cars every year past a certain age too
