Packing CV with grease ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2008, 03:12 PM   #1 (permalink)
View stumped's Photo Gallery
This ties in with my previous question on replacing the right axle half shaft on my 1989 Camry. The replacement axle's inner joint, the one with the 6 bolt holes, has no grease & has to be packed.
How much grease has to be packed into the boot & joint? Normally I'd pack bearings with all they could hold. But is it possible to over-stuff a boot where it might break open when in use?
stumped is offline   Reply With Quote
Old 09-28-2008, 02:05 AM   #2 (permalink)
88' camry v6 LE's Avatar
View 88' camry v6 LE's Photo Gallery
Grease capacity: 43 – 53 g (0.09 – 0.12 Ib) Inner joint
Grease capacity: 90 – 100 g (0.20 – 0.22 Ib) inboard tulip/ boot
88' camry v6 LE is offline   Reply With Quote
Old 09-28-2008, 02:21 AM   #3 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation Just get a reman?
Hey nice reply up there.
One reason I like this site sooo much
Great info.
Any chance the joint is bad too . Just buy a reman $55?
malayan is offline   Reply With Quote
Old 09-28-2008, 12:41 PM   #4 (permalink)
The more I look at the situation the more confused I get. The inner joint looks dry, except for a thin coating of oil. The Toyota manual, in bold print, does say do not compress the inboard boot. Therefore I presumed the boot should be packed with grease. I carefully squeezed it & figured I would start seeing some grease appear at the exposed end. But I did not. It just makes me wonder how much grease is in the boot. Or maybe its all settled at the small end.
I doubt you can ever get any grease into the boot through the inner end, so I'm presuming the boot does have grease. But I still have to pack grease to the center drive shaft as per the online Toyota manual, or to the open end inner end of the half shaft. The upper picture in the manual on page FA-39 could be the half shaft or the center drive shaft. Hard to tell. But the description does say center drive shaft. Is there actually room there for grease?
Where did you actually pack grease into?
Old 09-28-2008, 12:55 PM   #5 (permalink)
just a nobody
I usually put the grease into the joint itself, not in the boot. Just a little bit more than enough to cover the joints.
N.E.O.
Old 09-28-2008, 04:31 PM   #6 (permalink)
N.E.O.
Thanks for the reply.
That's what I planned on doing since I'll never get any in the boot. If you cannot get any in the boot it must be packed. But that is a presumption.
Old 09-28-2008, 06:05 PM   #7 (permalink)
just a nobody
Don't put too much in there it will be pushed back out. The boot is there to keep the dust and dirt or whatever from contaminating the joints, doesn't need any grease in there.
N.E.O.
