87 camry fuel filter, cant budge it! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2008, 06:02 PM   #1 (permalink)
View hfca's Photo Gallery
USA 87 camry fuel filter, cant budge it!
tried the bottom line and cant budge it, kinda a tough spot to get any leverage too, hit it woth penetrating oil, will try again tomorrow. Don't want to bend line either. Any hints? bottom is the 14mm/17mm, top is way easier, will do it when bottom is loose.
hfca is offline   Reply With Quote
Old 09-28-2008, 02:27 AM   #2 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation Penetrant is a good good thing!
Mine came off after the penetrant and 24 hours!
You might use a box type wrench made just for pipe nuts.
A regular wrench might strip the nut.
Godd luck!
malayan is offline   Reply With Quote
Old 09-28-2008, 10:24 PM   #3 (permalink)
got filter out of bracket, bottom line out, wrench on 19 mm side a and 14(same side/top), cant get filter off??? Hit it with PB blaster will try again tomorrow. grrrr.....
Old 10-01-2008, 03:46 PM   #4 (permalink)
Talking Got fuel filter off and swapped, runs lots better! :)
took it to the garage down the street and they had to use an impact wrench to get it off, filter mgr. date was Aug 2002, and dunno if it was just tightened way to much or from sitting, but hey for $40 they swapped it out for my new one in 45 mins, although I did tip the guy $15 AND BOY DOES SHE RUN FASTER/BETTER NOW! oops caps.....you could blow through filter but still seemed clogged.
