1991 Camry, Steering Wheel Options? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2008, 03:07 AM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
I bought a 1991 Camry (Just the 4cyl, no le/dx or anything, just camry)
The steering wheel SUCKS big donkey.
Are there any other steering wheels I can just pop onto it?
Nuke209 is offline   Reply With Quote
Old 10-11-2008, 05:30 AM   #2 (permalink)
Toyota. Possibilities.
PaulyJay's Avatar
View PaulyJay's Photo Gallery
any of these i guess as the aftermarket hub for the early camry's also fit them too........
TOYOTA 84-87 COROLLA,84-95 MR2,86-93 CELICA 2WD,87-90CAMRY, 87-96 PICK UP,88-91 COROLLA GTS,89-97 COROLLA,90-98 TERCEL, 90-96 4RUNNER,91-96 LAND CRUISER,92-97 PASEO. straight from the ebay listing for the hub. prolly look nicer to buy an aftermarket wheel and hub.
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
PaulyJay is offline   Reply With Quote
Old 10-11-2008, 11:57 AM   #3 (permalink)
2001 Camry LE
Oh snap, the paseo one fits?
I love the 3 spoke, smaller wheel. So I will get one soon.
Old 10-11-2008, 05:08 PM   #4 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I had this Grant wheel in my '91, then transplanted it into my '90 wagon. The wheel & hub was around $130, IIRC. Definately not cheap. It was a nice comfortable wheel & felt good, I loved it! But the smaller size totally blocked the top of the speedo.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 10-11-2008, 05:55 PM   #5 (permalink)
2001 Camry LE
Before I buy a Paseo steering wheel, what are all the parts that are needed to do the swap?
Old 10-11-2008, 06:05 PM   #6 (permalink)
HomeGrown's Avatar
Should just need the wheel and horn button. If it's the same hub, then it *should* just bolt right on. I don't really think there's anything additional you can remove or need to remove from the Paseo. You will definately need to take a wheel puller with you when you go to get it though.
EDIT: I hate to state the obvious, but don't mess with one that's got an airbag.
Old 10-11-2008, 07:20 PM   #7 (permalink)
2001 Camry LE
oh, this camry doesn't have airbags
doesn't even have a rpm gauge, just mph and fuel/coolant LOL
wheel puller? what's that
Old 10-11-2008, 09:10 PM   #8 (permalink)
HomeGrown's Avatar
Do a Google image search. Basically, it's a tool that has a main center bolt and 2 or 3 secondary bolts that thread into what you're pulling. You'll need a 2-bolt puller for a steering wheel. When you remove the horn button, there will be a large nut to remove. That's all that holds the steering wheel on. But once that's removed, the wheel still isn't going to budge, because it's on a tapered and splined shaft. The secondary bolts in your puller will bolt into holes in the steering wheel. The large center bolt will center on the main threaded steering shaft. When you tighten the center bolt, it will put enough pressure on the steering wheel hub to pop it loose. Might sound complicated, but it's a very simple procedure. You should be able to get a wheel puller at just about any auto parts store for pretty cheap.
Here's some pics:
This is a simple home-made one:
Here's a cheap one you might find at an auto parts store
(probably about $10)
Here's another one shown in use:
The 2 outer bolts are threaded into holes in the steering wheel, and he's tightening the center bolt to pull the wheel off.
Old 10-11-2008, 09:17 PM   #9 (permalink)
PaulyJay's Avatar
glad you stepped in there homegrown. cos being here in aus it's a bit hard to say where to get those kinda things. i've never needed one but then i usually end up clocking myself in the head taking them off. i'm going for a new wheel soon and if it wasn't for someone else asking i would've just kept forgetting about it. homegrown is right about the airbags. even if the battery is disconnected you can get a nasty surprise.
Old 10-11-2008, 09:26 PM   #10 (permalink)
HomeGrown's Avatar
Glad to help, PaulyJay
Yeah, I've tried removing wheels without a puller, but it's definately NO fun.
Old 10-12-2008, 12:08 AM   #11 (permalink)
2001 Camry LE
thanks thanks thanks, will update, hopefully take pics when i'm doing one.
Old 10-13-2008, 12:44 AM   #12 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Do you need a Toyota SST steering wheel puller, or can you use any?
Only asking as I've ruined a harmonic balance/crank pulley from using a universal puller; instead of the genuine which would've got it off without destroying it. This was NOT on a Toyota, but the same rules could apply. I'm very paranoid and like to be sure.
And paulyjay, you can pick up a puller at most auto accessory stores like Autobarn or Super Cheap (universal ones).
Jimnist is offline   Reply With Quote
Old 10-13-2008, 08:12 AM   #13 (permalink)
HomeGrown's Avatar
I used a generic puller when I changed wheels on my Camrys. I believe the Camry wheel has (2) 8MM tapped holes in the frame for pulling.
