Originally Posted by Boost_man
would a year specific model be easies to swap? he was thinking of using a 91 turbo supra motor he found but im wondering if his factory sensors would all bolt on. im down to help him with the swap but i dont wana have to do a lot of hacking and adapting with the wiring ya know?
You will need to start with a motor from a similar chassis... in the case of the Camry, that leaves you with the Camry and Celica.
What are the power goals and budget? Turbo? N/A? No matter what, you will have to do a lot of wiring. You will need the motor, wiring harness, ECU and all sensors that match the motor. Also consider upgrading the transmission at the same time. If you choose well, you won't have to do a lot of other modifying.
Here's mine:
-Charlie
PS: Some decent motor options with their aprox. stock horsepower range: 3s-ge (130-210hp) , 3s-gte (190-265hp), 2vz-fe (155hp), 3vz-fe (175hp), 5vz-fe (175hp+torque!), 1mz-fe (190-210hp), 3mz-fe (220hp)
