Help with Water Pump 91 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2008, 06:27 PM   #1 (permalink)
View GregElliott's Photo Gallery
2nd Generation Help with Water Pump 91 Camry
I have a 91 Camry, 3SFE, 16 Valve DOHC, 2.0L
In the Toyota repair manual it states that you need to "remove the water pump bolts in the sequence shown." But it doesn't show the sequence.
Does anybody know the sequence and what the purpose of the sequence is?
GregElliott is offline   Reply With Quote
Old 10-18-2008, 07:16 PM   #2 (permalink)
just a nobody
I am not aware of any specific sequence, if there is any, they may be located in the picture itself. Probably have something to do with the different size of bolt used, 12mm and 10mm hex head bolts. I usually take off the bigger ones first and then the smaller ones, never had any problem; reverse for installation.
N.E.O.
Old 10-18-2008, 07:33 PM   #3 (permalink)
Toyota. Possibilities.
PaulyJay's Avatar
View PaulyJay's Photo Gallery
on the mention of repair manual, does anyone know if the manual that used to have a sticky is still around? cos if it's not i have it if anyone wants it in aus, i might even do a torrent for it if noone else has.
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
PaulyJay is offline   Reply With Quote
Old 10-18-2008, 09:22 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The 5SFE 4cyl sequence is the top bolt first, then the aft bottom bolt and finally the middle bolt. The 5sfe requires only 82 inch-pounds of torque.
This sequence is shown on the picture in the manual. Hope that helps.
Kep
Old 10-18-2008, 09:46 PM   #5 (permalink)
Kep
well, in the manual it says to reinstall the bolts "in the sequence shown" and it actually shows it that time. Common sense would tell me that the reverse would be the order in which to remove them but I'm just not sure.
Old 10-19-2008, 07:13 AM   #6 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Funny, my manual (Gregory's) it says that only the left side (looking straight at it with exhaust manifolds on the right) bolts need loosening in a specific order. That is, centre, bottom and then top. Then it says "Installation is the reversal of the removal procedure..." So yes, you are right Greg
And Kep, he has a 3SFE, not a 5SFE.
Jimnist is offline   Reply With Quote
Old 10-19-2008, 09:07 AM   #7 (permalink)
just a nobody
Are you replacing the back cover too?
N.E.O.
Old 10-19-2008, 02:59 PM   #8 (permalink)
Well, my goal is to just replace the pump so far.
Should I replace it for any reason?
Old 10-19-2008, 04:00 PM   #9 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Failure to remove the cover will result in leak between the pump cover and cylinder block[common comebacks when I was working in the shop]. Remove complete pump and replace o-ring at the cover to block mating side and another o-ring on the heater pipe.
If corrosion is present on the back side of pump cover apply 1/8 inch bead of sealant around the ring.
Doctor J is offline   Reply With Quote
