Alternator replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2008, 07:04 PM   #1 (permalink)
View Phils Camry's Photo Gallery
I have a 91 Camry, 4 cyl, auto trans with 210k. I need to replace the alternator. It looks straightforwardly simple. Are there any unforseen tricks to this?
Phils Camry is offline   Reply With Quote
Old 10-18-2008, 07:12 PM   #2 (permalink)
just a nobody
No, just make sure you disconnect the battery.
N.E.O.
Old 10-18-2008, 07:31 PM   #3 (permalink)
Toyota. Possibilities.
PaulyJay's Avatar
View PaulyJay's Photo Gallery
N.E.O. has forgotten the only problem with anything that looks straight forward. MIDGETS!
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
PaulyJay is offline   Reply With Quote
Old 10-18-2008, 09:12 PM   #4 (permalink)
View GregElliott's Photo Gallery
lol.
if the alternator has been on for a long time you may need to pry it out of the bracket with a large screwdriver.
GregElliott is offline   Reply With Quote
Old 10-18-2008, 09:30 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The plastic cover on the pos terminal is somewhat delicate, be gentle with it. Loosen the locking bolt, Loosen the pivot bolt. Loosen the tensioning bolt until the belt can be slipped over. Watch the wires when dropping the alternator to make sure they aren't strained when it drops. Before trading in the core make sure that the replacement pulley is the same size (mine was different).
Kep
Old 10-18-2008, 09:57 PM   #6 (permalink)
just a nobody
Dxxx, you were suppose to remind me before I post, not joke about my half gone memory afterwards. It is actually not to bad since I at least remember about disconnecting the battery part, because I usually found out about that when the sparks start to fly.
N.E.O.
Old 10-18-2008, 11:19 PM   #7 (permalink)
PaulyJay's Avatar
not the only thing that'll fly if you don't disconnect the battery! lol
Old 10-19-2008, 12:24 AM   #8 (permalink)
just a nobody
Dxxx, there you go again, so what part of you gone missing this time?
N.E.O.
Old 10-19-2008, 02:20 AM   #9 (permalink)
PaulyJay's Avatar
i've seen a few idiots (those who think they know best) and a few clueless people (those who didn't know how bad it could be or were having a bad day) shock themselves quite badly. and there's the "extreme" possibility of shorting out all your wiring and electrical components.
Old 10-19-2008, 04:12 AM   #10 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Sometimes the alternator is hard to pull from its mounting bracket. It usually takes place if pivot bolt was too tight . Use large screwdriver or flat side of lug wrench to pry between the bracket and the alternator housing. This shoud help to remove alternator.
Doctor J is offline   Reply With Quote
Old 10-19-2008, 08:11 PM   #11 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
The only issue that I had when I did mine was the pivot bolt broke. Other wise it was a 5 minute job.
zppeacock is offline   Reply With Quote
Old 10-21-2008, 02:21 PM   #12 (permalink)
Thanks to All
I want to thank everyone for their input. I replaced my old alternator which had 110K on it with a remanufactured Denso replacement. The job was a breeze. It took about 10 minutes to do with NO scraped knuckles. THANKS to ALL of you.
Old 10-21-2008, 02:34 PM   #13 (permalink)
Oops. My alternator had 210K on it. It was original.
Old 10-21-2008, 02:34 PM   #14 (permalink)
just a nobody
Gee, I want to see some blood.
Glad to hear that you have it going again.
N.E.O.
Old 10-21-2008, 02:35 PM   #15 (permalink)
just a nobody
Oh well, it is old!
N.E.O.
