Download the “EWD90” PDF file from
www.camrystuff.com, second generation
Good ground is the any bolt in the body within easy reach
The diagram above is not very good: there are
2 SPST normally CLOSED
limit switches at the end of belt travel track, one of each end;
The automatic shoulder belt switch is located inside the door latch
- Remove panel from the pillar to expose 4-wire connector;
- Manually rotate motor shaft toward the seat about 1/3 of the way
- With the driver door open turn the key to the ON
If belt moves toward the windshield—the motor is good, check
front limit switch and switch
in the door latch.
If belt is not moving:
a] the motor or computer is defective;
b] the switch in the drivers door latch has bad ground or defective
Turn ignition OFF and separate 4 wire connector exposed at the first step.
This is the best point to start.
Using the diagram on the page number I specified in “seat belt repair”, test for continuity the wires to going to the door latch switch. One should have continuity to the ground with door open and another with door closed [‘either-or’].
If neither wire has continuity, suspect damaged ground wire; take the door apart and repair.
