Odd request: Pics of power steering in SV21 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2008, 06:13 AM   #1 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Hey everyone, This is going to seem like an odd request, but would someone be kind enough to take some pics of the power steering in a 2nd gen Camry for me with the 3S-FE engine? Asking as i'm fitting power steering to my car that currently has manual/standard rack and pinion steering. If possible, can you take particular pics of: >How the reservoir is mounted in the engine bay >where the high pressure and return hoses are mounted (seems to do a very funny loop and i'm not dropping the engine out, so it'll be tough) >where the pump is mounted (have a vague idea, but not 100% sure) >Which hose goes into what for the pump (where the hoses screw back in to the pump. Don't know which is high pressure and which is return) Many thanks and any help is appreciated
Jimnist is offline   Reply With Quote
Old 10-24-2008, 12:59 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Do you have *all* the parts necessary? Any way you can to a junkyard and just take a look?
Also, note that the LHD and RHD steering racke and lines are somewhat different. The factory service manual should also have some drawings/diagrams that show what is what.
-Charlie
Old 10-24-2008, 01:09 PM   #3 (permalink)
View GregElliott's Photo Gallery
GregElliott is offline   Reply With Quote
Old 10-24-2008, 01:15 PM   #4 (permalink)
Old 10-24-2008, 01:19 PM   #5 (permalink)
Old 10-24-2008, 02:44 PM   #6 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation Nice One Greg
Now That's a Response!
Even though you don't want it to be a major job.. It might
You will want to drop the crossmembers and muffler pipe to get good access. I ended up having to do this just to swap the pump.
Good Luck and thanks again Gregg.
malayan is offline   Reply With Quote
Old 10-24-2008, 10:13 PM   #7 (permalink)
セクシーの定義
Wow! Thank you Greg!!!!! Thank you sooo much!!!!!!
And Charlie, yes, i do have all the parts. But the wrecker took it out for me. Also, i don't have a factory service manual and by service manual doesn't include many pics of it. Only the rack on the car. No schematic of where the pipe go. The rack looks exactly the same, except rotation 180 to suit your LHD.
Malayan, i think you're right about having to drop the cross members out. I could only move the rachet about 2cm and i still haven't un-done one bolt yet. Do you think it will be easier to take off the crossmember and exhaust or to just lift the whole engine out? And when you say muffler pipe, do you mean the whole system from the exhaust manifold or just the front end part where i'll be working?
Old 10-25-2008, 07:21 AM   #8 (permalink)
Toyota. Possibilities.
PaulyJay's Avatar
View PaulyJay's Photo Gallery
i'll attempt to take some "photo's" of mine tomorrow for you. mines the same side so it should help a bit more. good luck with it. we did it to a falcon a while back and that wasn't so easy. and there's more room! lol!
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
PaulyJay is offline   Reply With Quote
Old 10-25-2008, 07:25 AM   #9 (permalink)
セクシーの定義
Cheers Pauly!
Old 10-25-2008, 07:32 AM   #10 (permalink)
PaulyJay's Avatar
you do realise if i do this i will own your soul for all eternity? cheers mate, anything for a fellow camrite!
Old 10-26-2008, 01:45 AM   #11 (permalink)
セクシーの定義
haha, very funny mate XD. I was just going through another manual and stumbled onto some important information that wasn't in my other manual (yes, i have 2 service manual, don;t ask why) Anyways, it goes on about a vacuum sensor. What's that for? Where does it connect up to? It says there's a hose that's supposed to go over the sensor. Also, it says: "Clean the exterior with a suitable solvent ensuring that the solvent does not contact the pulley oil seal". If my memory serves me, i'm pretty sure i doused the whole pump with foaming degreaser spray. Does i mess up the oil seal in the pump or will it be alright?
Old 10-27-2008, 12:56 PM   #12 (permalink)
white90dx's Avatar
You'll be fine without the vacuum 'sensor'. It isn't actually a sensor though, it is an idle-up valve that lets a little extra air into the manifold when the power steering pressure goes up at low engine speeds. There is an air pipe on the back of the manifold on the power steering models that connects to this and then runs up to the manifold near the A/C idle-up valve.
Oh, and the oil seal should be fine.
-Charlie
Old 11-03-2008, 05:30 AM   #13 (permalink)
セクシーの定義
Bump?
I've looked through 2 manuls and have searched everywhere, both on TN and the internet and I still kinda need help on two points. Please help me out.
1) Don't know how the universal joint should be positioned/aligned when the steering is straight ahead. How should it be?
Reason? I undid BOTH pinch bolts and didn't mark it. When i was removing the rack, it fell off. Can i just mimick the position of the uni joint in my uncles Camry to mine? Would that work? He's got a 3rd gen v6 Camry.
2)How do I 'center' the steering rack?
I bought it from wreckers and not sure it's straight (i.e. car will go in a stright line in current position) at the moment.
Thanks
Old 11-03-2008, 08:44 AM   #14 (permalink)
PaulyJay's Avatar
hey guys. been a bit sloppy this past week or two. been lookin after the grand parents. grandmother may have lung cancer. will have a look at the stuff tomorrow if you still need the photo's. jimnist, send me a text on 0400577426 and i'll just mms them straight to you if you want.
Old 11-03-2008, 11:23 PM   #15 (permalink)
セクシーの定義
Thanks mate. But i don't think my phone can support mms. Plus, i lost the cable, so i can't transfer it to my computer, blow it up and print it. Whenever you're free and have time, you can take the pics of where the hoses are routed and mounted and the uni joint.
Hope your grandparents get well soon.
-Jim
