The fuel pump had been sitting in the old fuel for the past four years, so whether you run it or not, it is already in the old fuel. Furthermore, you will be putting a new fuel filter on regardless of whether you have the old fuel through it or not. When I said pump it out with vehicle fuel pump, I don't mean running the engine. Simply disconnecting the fuel line from the fuel filter when you change the fuel filter, hook up the feed line to a container. Then connect the 'Fp' terminal in the diagnostic connector to a power source and the fuel pump will run without the key on.
N.E.O.
