90 Camry AT shift points - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2008, 11:32 AM   #1 (permalink)
View z31kid's Photo Gallery
Got a 90 4cyl 3SFE and recently had some tranny work done. When I originally got it back it would shift into OD between 30-35mph. Since it would seem to bog I took it back to the shop and they adjusted it so it now shifts more at 40mph. It seems that this is still a little too high and I want to adjust it a little lower. How do you adjust it?
z31kid is offline   Reply With Quote
Old 11-04-2008, 11:56 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
First verify that you have non-ect transmission [no power/norm pushbuttton] next to the handbrake handle;
Then with engine off, check the position of the kick-down cable.
the transmission should go into O/D at about 45 mph at 50% throttle acceleration
Doctor J is offline   Reply With Quote
Old 11-06-2008, 08:26 AM   #3 (permalink)
Nope ... it is an ECT-type which is why I am confused to how it was adjusted at the shop as I've read the FSRM and saw that it's conputer controlled .... maybe he changed the TC. I did have to have the tranny rebuilt so maybe he put the wrong TC in with a different stall and swapped it when I brought it back.
So theres no other adjustment?
Old 11-06-2008, 11:11 AM   #4 (permalink)
Doctor J's Avatar
Make sure that transmission is not overfilled: even 1/3 of qt overfilling causes early upshifts.
the tc must be 11 inches dia and it fits 83-to 94 4-cylinder Camry; moving the shift cable will not change shift timing on ECT.
