The reason I picked this project is because no welding was needed to finish it as I do not know how to weld
The white wagon owner [seen on the picture behind the wheel] let me use his garage while I did head swap on my 79 Supra, so after his car was hit by the backing-up bus in L.A, he asked me about tentative estimate how much it will cost to fix it.
After realizing that the frame components and inner fender had no damage, and the only one welded part can be straightened with hammer and home made anvil, I decided give this thing a shot.
I was able to bring the a/c condenser back to it's place without damaging the a/c tubes.
The hardest part to find was the passenger side fender, as they got damaged most often.[You can see the blue pinstripping on it which we un-glued later using alcohol.
