Quick Questions about Instrument Cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2008, 06:38 PM   #1 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
I have a couple quick questions:
How hard is it to take the whole gauges cluster out. I see the three screws on the topside of the black cover that surrounds it, but how hard is it to get that off, and whats the nightmare like behind it?
Oh, and i can just connect the RPM gauge cluster from a Manual car if i ever find one?
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 11-05-2008, 06:56 PM   #2 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
well the center screw on the black cover is the hardest to get off if you dont have a short screwdriver.
other then that is pretty strait forward.
Yes I would imagine you would need a gauge cluster from either a manual 2.0 car or an LE 2.0 car.
I think both have the cluster your looking for.
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 11-05-2008, 08:25 PM   #3 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Yep, it's a plug-n-play swap. Several people here have done it, incuding myself. Don't recall how many screws you have to remove, but it was pretty simple overall. Should find plenty of info on it here if you do a search.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 11-05-2008, 08:35 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
there's those 3 and there's 2 more on each side where the defrost/hazard buttons are and just pull it off and the cluter's held on by 4 screws.
Old 11-05-2008, 08:48 PM   #5 (permalink)
View GregElliott's Photo Gallery
Just unplug one and plug the other right in? no modifying? ... you are telling me that connector for the big ass fuel gauge would register correctly on a smaller guage?... and how does the tach plug in?
GregElliott is offline   Reply With Quote
Old 11-06-2008, 12:09 AM   #6 (permalink)
disregard's Avatar
yeah man its plug and play the computer is already looking for it.and when it finds the tachometer it uses it lol. the fuel gauge is indeed smaller on a tach cluster but it uses the same basic signal so everything still works good.
Old 11-06-2008, 01:21 AM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
it's all wired .. it's just the none tach cluster doesn't use that signal wire that's all
Old 11-06-2008, 09:47 AM   #8 (permalink)
日産自動車パワー!
JMSports's Avatar
Great, now i might pull it apart and have my brother add vinyl to it and make it cool colors, lol. But ye.
Now on to finding one with an RPM gauge.
Old 11-06-2008, 12:49 PM   #9 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
You can also swap your current speedo over to the new cluster - as long as it matches the current look (they changed between two slightly different mechanical designs around 88/89). That way even your odometer stays correct.
-Charlie
Old 11-06-2008, 01:40 PM   #10 (permalink)
日産自動車パワー!
JMSports's Avatar
-Charlie
Good idea
Old 11-06-2008, 03:48 PM   #11 (permalink)
HomeGrown's Avatar
As Charlie mentioned, there was a slight design change which required me to pull the speedo needle & swap faceplates in order to be able to swap out the speedo unit when I put the tach cluster in my '91. The mounting holes were slightly different on the 2.
Was still no big deal, and the swap was flawless & perfect. I was a bit nervous when the gas gauge was getting close to "E" on my first tank of gas after the swap, but everything was great, including the low-fuel warning light.
