Need info on changing transaxle fluid on 1991 5spd Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2008, 11:52 AM   #1 (permalink)
View Ledlaptop's Photo Gallery
I just replaced the passenger side axle shaft on my 1991 5spd 4cyl 2WD Camry.When I removed the axle alot of the transaxle fluid came pouring out.What I'm trying to find out is: Where are the fill and drain plugs for the transaxle and what type of fluid is needed for it?
Ledlaptop is offline   Reply With Quote
Old 11-06-2008, 01:06 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Fill plug is on the front of the transmission, below the starter. Factory fluid is Dexron II/III ATF. (yes, ATF for the manual transmission) Just fill 'til it starts coming out the fill hole.
-Charlie
Old 11-06-2008, 02:49 PM   #3 (permalink)
-Charlie
What came out of the transaxle was yellow oil,not tranny fluid. Mine is a 5spd transmission.
Old 11-06-2008, 03:25 PM   #4 (permalink)
View toyomoho's Photo Gallery
Depends on year of car and engine. Toyota used both gear oil and auto trans fluid in manual trans.
4 cylinder lists Dexron, V6 engine lists gear oil.
If you want, use 75W90W or 80W90W gear oil.
Old 11-07-2008, 12:24 PM   #5 (permalink)
white90dx's Avatar
Hondas from those years used motor oil in some of their manual transmissions... maybe the previous owner made a mistake? Go with Dexrom III ATF or 75w90 gear oil.
-Charlie
Old 11-07-2008, 08:09 PM   #6 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation This wierd
I was replacing a manual in a 91.
Come to find out it had (yes) Dextron III in it.... WOW!
Last time I did a (american made) manual was 90W???
Oh well I figured maybe the previous owner made a mistake but checked the vin Number on the tranny and it came out of a 87 Celica
Looked up the 87 celica and sure enough it specified Dextron . Filled till overflowed ....That was 100 miles ago. running Good....
I guess it comes down to what year tranny it really is..
Good Luck.....
malayan is offline   Reply With Quote
