1991 3S-FE Automatic Transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2008, 10:24 AM   #1 (permalink)
View Phils Camry's Photo Gallery
I have a 91 3sfe auto trans. From what I understand, the transfer case and drive axle case are separate units. Do I need to fill them separately with transmission fluid or does filling the auto transmission also fill the drive axle case?
Phils Camry is offline   Reply With Quote
Old 11-08-2008, 10:36 AM   #2 (permalink)
just a nobody
Do you have an AllTrac?
The filler plug for the differential is at the back of the transaxle close to the steering rack.
N.E.O.
Old 11-08-2008, 12:11 PM   #3 (permalink)
I have a Camry DX FWD.
Old 11-08-2008, 01:36 PM   #4 (permalink)
Gameroom cash: $302555
I would assume that the differential is separate on the 3SFE engine. I know it is separate on the 5SFE engines, so I'm assuming the 3SFE is the same.
One additional bit of advice if you do attempt to drain and refill the differential. Remove the fill plug first. It avoids panic if you remove the drain plug and then have problems removing the fill plug. Don't ask me how I know this.
Mike
Old 11-08-2008, 01:38 PM   #5 (permalink)
just a nobody
Mike
How did you know this?
Good suggestion!
N.E.O.
Old 11-19-2008, 02:55 PM   #6 (permalink)
View kevinwscott's Photo Gallery
Transmission Fluid
If your transmission is the A140E (which I think it might be) The differential and the main part of the transmission have to be filled seperately. You fill the main part through the dip stick tube. To fill the differential you have to put the car up on jack stands (should have car level) and fill the differential. The plug is on the side. The differential is where the front drive axles are attached to the transmission.
kevinwscott is offline   Reply With Quote
Old 11-21-2008, 04:01 PM   #7 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation hey Kevin
Kevin....you are talking about a ALLTRAC not FWD right?
From what I have seen on all the 140e that I have swapped for a "FWD" I fill through dipstick.
"ALL TRAC ONLY" have the extra little fill plug by the steering rack side right???
malayan is offline   Reply With Quote
