alright ill give you a little background on the car
bought it for a dollar from my sisters boyfriend because the clutch was dying
two months after i got it it was completly gone mechanic was going to charge me 1000 dollars to replace it, couldnt afford it, so i thought id try it myself. long story short no one thought i could do it, but i did with a lot of help from this forum. BUT now i have a problem that i need to address relatively soon
I think the last time the timing belt was replaced was around 100k mis and now it has 235k mis and i need to replace it. I have the parts and attempted in the past but got stuck. anyway there are two nuts on the bottom of the left motor mount that i tried to get off with an extender and deep socket 14mm to no avail, actually i ended up stripping the nut.
SO my question here is how to i remove a rounded off nut that is nearly impossible to access?
