88 camry won't start when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2008, 09:12 PM   #1 (permalink)
View oldschoolcamry's Photo Gallery
I have an 88 camry, when i start it when the motor is cold I have to try 6 to 10 times to get it crank. The starter turns but it wont stay running. It runs for a second the dies. After a bit it will stay running. I let it warm up it its fine. If I try to drive it after I get it crank it will just pop and die. Have done a new turn up. Plugs, wires, dist cap, rotor button, the only code I am getting is 51
oldschoolcamry is offline   Reply With Quote
Old 11-18-2008, 09:28 PM   #2 (permalink)
Also it's a 2.0
Old 11-18-2008, 10:00 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
sounds leaned out when cold
Old 11-19-2008, 07:36 AM   #4 (permalink)
Gameroom cash: $302555
Check the resistance of the "cold start time switch". It's the one under the brown plastic connector on the coolant port coming off the cylinder head, just to the driver's side of the engine as you are standing in front of the car. It's this sensor that is responsible for telling the ECU to richen up the fuel mixture for a cold engine start. You will need a digital volt ohmeter and the specs from any manual to do this. Even a bit out of spec can cause this cold starting problem. If it is out of spec, you will need to replace it. I believe this is a dealer only part.
Mike
Old 11-19-2008, 06:06 PM   #5 (permalink)
How many wires on that connector?
Old 11-19-2008, 11:10 PM   #6 (permalink)
It should be a 2 wire connector.
Mike
Old 11-19-2008, 11:27 PM   #7 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
On my most recent Corolla (4AFE) the switch tested within spec and it ended up being the cold start injector itself: it wasn't dripping any fuel into the plenum when it was supposed to.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-20-2008, 10:31 PM   #8 (permalink)
2nd Generation
Any other suggestion?
Old 11-21-2008, 03:26 PM   #9 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation U Pull It!
cold start time .. YES! I HAVE DONE A FEW...
At my local yard I could get both for cheap. Don't go to dealer unless no Yard available.....
As you will note that these are one of the first things to be pulled so get a fresh inventory car....
I even go to ebay before dealer...
DEALER = LAST RESORT!
malayan is offline   Reply With Quote
