1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
Got a few problems when I let my 1990 Camry Wagon sit outside over night. During the Summer it has been starting just fine. But now with the winter weather its not.
Problem 1: This morning I got in it, and Turned the Key I got nothing, So I kept on trying and after about 7 times turning it back and forth I got it to crank and it fired right up.
Problem 2: It will fire right up in the morning on the first crank of the starter. But it will miss badley for about 30 seconds and then clear up and run fine.
Anyone have a clue why its doing these things? It only happens when it gets really cold at night and only on the first start in the morning. I can go to work and leave it sit for 8 hours and it will start fine.
1. If you are hearing 1 click you most likely have the common worn starter solenoid contacts problem. Do a search on this forum for "starter contacts" and read up on the problem and it's cures. If you are hearing multiple rapid clicks, you have a weak battery problem (bad battery, bad alternator or loose alternator belt), or corroded connections either at the battery posts/terminals or at the starter itself.
2. For the second problem, check the cold start time switch. It's the one under the brown connector on the water port, on the driver's side of the engine. You will need a digital volt/ohmeter and the specs from any manual to do this.
im thinking the starter uses more energy when really cold.
if the contacts of the starter is dirty or corroded it wont get all the energy it needs to start in REALLY
COLD weather. But when its warmer out it takes less energy to start because the parts move easier.
Just my 2 cents
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
Your really asking why the starter doesnt work as well in the cold? Are you serious?
Its a bit common sense, when things are cold, they tend to resist motion, because as you know heat and energy go hand in hand. Lack of heat, lack of motion, more energy required by the battery to start the car.
I would get the battery checked for voltage, and make sure all the cells are full, and check the starter.
this seems to be a common problem in Tasmania Australia where i live. not for me, but a few of my mates have an issue. a new starter motor fixed it in one case. a more extreme case i know of a while ago was a result of a leak somewhere causing ice to seize the moving parts. this was a while ago though, and i don't really understand it.
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
Put in the starter relay that Doctor J suggests in one of the stickies here on the forum. It is a weak starter solenoid. With the colder weather, the battery loosesa a bit of output and causes the problem.
You can also try turning off all accessories while cranking (no interior fan, lights, no foot on brakes, etc.). If that helps, then add the extra relay and it should fix the problem.
-Charlie
"1. If you are hearing 1 click you most likely have the common worn starter solenoid contacts problem. Do a search on this forum for "starter contacts" and read up on the problem and it's cures."
Mike
