88 takes its time getting into top gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2008, 08:32 PM   #1 (permalink)
View cvandiv's Photo Gallery
2nd Generation 88 takes its time getting into top gear
hello,
i've got an 88 4-cyl automatic wit 166k miles, and have recently done a whole lot of work on it (exhaust system, brake and fuel lines) so it's running great except for one thing.
at work, i park < 1/4 mile from the interstate. so, when i leave work, i almost immediately am on the interstate. the problem i am posing about shows up only when i'm going from "cold" to interstate speeds quickly. i accelerate up to speed, but my transmission gets "stuck" in the next to last gear and i can't go any faster than 50mph or so (and i'm in michigan with 70mp interstates :o ) so it stays this way for about a half mile or so, then drops into the highest gear (it's super consistent, always happens at about the same point)
like i said, it's running great other than this little hiccup, but i'd like to take care of it before it turns into a big deal.
thanks!
cvandiv is offline   Reply With Quote
Old 11-22-2008, 09:56 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
its supposed to stay in 3rd until it gets warmed up
Old 11-22-2008, 10:24 PM   #3 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
It does this to warm up the cat quicker.
zppeacock is offline   Reply With Quote
Old 11-23-2008, 01:18 AM   #4 (permalink)
View kesando's Photo Gallery
Is this function controlled by the ECU?
kesando is offline   Reply With Quote
Old 11-23-2008, 05:12 AM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
If you have Power/Normal push button next to parking brake handle, the answer is yes, if not, then it is controlled by thermo switch similar to the fan switch located on the top of the upper radiator hose outlet in front of the distributor.
the warm up delay feutre was added to Toyota in late 79; failure of such device almost resulted in unnecessary tranny exchange [80 cressida].
The customer was lucky that she let me to check the car before proceeding with R&R back in 1996...
Doctor J is offline   Reply With Quote
Old 11-23-2008, 10:05 AM   #6 (permalink)
View lionheart03's Photo Gallery
I had this same problem on my 91 Camry 3SFE, 5 speed auto. When the temps started to drop lower than 50 degrees, my car would do the same thing yours did. I later determined that my t-stat was stuck open, and the car would take forever to heat up. My heater also wasn't working very good. If I let the car sit and idle a bit, it would warm up, but once I took off driving, you could watch the temp gauge go way down.
Replacing the t-stat fixed the problem. The car warmed up allot faster, shifted better, and my heater worked!
lionheart03 is offline   Reply With Quote
Old 11-23-2008, 06:00 PM   #7 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
I let my car sit a few minutes every morning because the temp here lately has been around 30 degrees.
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 11-23-2008, 09:36 PM   #8 (permalink)
Yeah, I let the car run for a few then I drive at low RPM until at operating temperature. BTW my tranny "bucks" a little into gear when shifted into drive cold.
Old 11-24-2008, 10:13 AM   #9 (permalink)
日産自動車パワー!
JMSports's Avatar
Theres one way to get around it then, buy a stickshift.
Old 11-24-2008, 06:17 PM   #10 (permalink)
sounds exactly like what mine does.
thanks all!
Old 11-25-2008, 10:06 AM   #11 (permalink)
View typesix's Photo Gallery
Better to drive the car at low rpm, it will warm up faster with a load, than unloaded and idling. Plus save some money instead of burning it up faster.
typesix is offline   Reply With Quote
