3sfe vacuum - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2008, 01:00 PM   #1 (permalink)
View rshep's Photo Gallery
3sfe vacuum
My vacuum reads 22 inch-Pd's and steady as a rock. If I had a vacuum leak, sticky valves or out of adjustment wouldn't it read different? The reason I'm asking is that the car has a horrible vibration when at idle. I changes all the mounts and did a tune-up. It just sames to get worse and worse.
rshep is offline   Reply With Quote
Old 11-27-2008, 02:18 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
how fast does it idle?
Old 11-27-2008, 08:09 PM   #3 (permalink)
I set it at 750.
Old 11-27-2008, 08:58 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
does it run ok?
Old 11-28-2008, 08:32 AM   #5 (permalink)
runs fine. Just bad vibration at idle.
Old 11-28-2008, 09:33 AM   #6 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
What kind of vibration? Through the whole car or just when you watch the engine idling with the hood open?
And it goes away when you drive it?
Jimnist is offline   Reply With Quote
Old 11-28-2008, 09:40 AM   #7 (permalink)
Vibration goes away at about 1200 rpm. It's really bad when I put it in park or reverse. I cleaned the EGR valve and throttle body. It made no differance.
Old 11-28-2008, 09:58 AM   #8 (permalink)
セクシーの定義
If it's really bad in park or reverse, maybe it's a problem with the automatic transmission?
Old 11-28-2008, 11:28 AM   #9 (permalink)
Are there any vacuum hoses going to the transmission?
Old 11-28-2008, 01:37 PM   #10 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
No vacuum goes to transmission.
Any connections between the exhaust system and body [bad hangers, etc?]
Where are you attaching yor vacuum gage?
Doctor J is offline   Reply With Quote
Old 11-28-2008, 05:07 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
what mounts have you replaced so far?
Old 11-28-2008, 07:17 PM   #12 (permalink)
I attached the vacuum gauge to the intake manifold. I replaced the front twist mount by the radiator and the trans mount by the firewall.
Old 11-28-2008, 07:51 PM   #13 (permalink)
Doctor J's Avatar
These mounts are not causing vibration on park.
I would suggest to:
*check the right front [timing belt mount] mounting bolts; ithey are tight replace this mount.
* crack in the center mount causes bad vibration in gear, while holding car stationary with the brakes]
Old 11-28-2008, 07:59 PM   #14 (permalink)
Where is the center mount located ?
Old 11-28-2008, 11:25 PM   #15 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
does the mount by the timing belt have a bolt going straight down in the middle of it?
