one dim headlight one bright headlight - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2008, 05:14 PM   #1 (permalink)
View ninja771's Photo Gallery
2nd Generation one dim headlight one bright headlight
ive had this problem for a while and its been bugging me. the drivers side headlight is bright (normal) and the passengers is dim (like the stock bulbs) i have silverstars installed in both headlights and i cleaned out the harnesses. what else could cause this?
ninja771 is offline   Reply With Quote
Old 12-09-2008, 05:18 PM   #2 (permalink)
Banned
View Slowbro's Photo Gallery
My wife has this problem with her car, its do to bad connection at the couplers. Where the wires actually connect to the coupler is the problem in her car. Mess around with your head light on without shocking yourself and see if it brightens with a little play.
Slowbro is offline   Reply With Quote
Old 12-09-2008, 05:51 PM   #3 (permalink)
2nd Generation
when you say coupler you mean the connector between the wire from the bulb to the wire to the car correct?
Old 12-09-2008, 10:18 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
clean up the headlite grounds too
Old 12-10-2008, 10:00 AM   #5 (permalink)
Banned
The part I'm talking about is when you remove headlight, there is usually a connector between the headlight and the wire leading to the battery that you have to unclamp. The wires can be loose with wear and tear that feed into the coupler and some play might be needed.
