Fault codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2008, 03:59 PM   #1 (permalink)
View leepratt's Photo Gallery
Fault codes
Can anyone tell me what fault codes 31 and 51 mean?
leepratt is offline   Reply With Quote
Old 12-10-2008, 04:58 PM   #2 (permalink)
View toyomoho's Photo Gallery
Code 31: Problem with MAP sensor or open or short in its wiring
Code 51: Switch Condition Signal Circuit.
Throttle position sensor, Park/neutral or A/C amplifier switch circuit.
Old 12-10-2008, 05:38 PM   #3 (permalink)
Thanks heaps mate.
Old 12-10-2008, 08:42 PM   #4 (permalink)
just a nobody
What year is your car? Don't think Gen 1 and 2 have MAP, air flow meter maybe?
Code 51 can be trigger when you are checking for codes. Suggest clearing it first and see which one comes back or if any comes back.
N.E.O.
Old 12-10-2008, 09:58 PM   #5 (permalink)
View oldschoolcamry's Photo Gallery
I got a code 51 when my coolant temp switch wasnt getting good connection.
oldschoolcamry is offline   Reply With Quote
Old 12-10-2008, 10:03 PM   #6 (permalink)
"87 model. I know she hasn't got map, just translated as air flow.
How do you clear codes?
Will check all connectors to i think, just to be on the safe side.
Old 12-10-2008, 11:54 PM   #7 (permalink)
just a nobody
Pull the EFI fuse will clear the code. Make sure you have good pin tension for the AFM connector terminals too.
N.E.O.
Old 12-11-2008, 08:03 PM   #8 (permalink)
Yup was loose connection on AFM.
Thanks for your help N.E.O
Old 12-11-2008, 08:48 PM   #9 (permalink)
just a nobody
Great, good to hear that!
N.E.O.
