88 camry flywheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2008, 12:03 AM   #1 (permalink)
View Snorbert's Photo Gallery
USA 88 camry flywheel
i am putting a 5 speed manual transmission in my car and i cant find a flywheel toyota said they had one but wanted $340 for it so i went to the parts house *all of them* and ordered the one showing for my car along with the cutch kit the kit is right but the flywheel showing for it doesnt fit the kit or my old kit it needs to be 12" in diameter with 120 teeth 6 bolt crank flange and the disc is 8 7/8 the flywheel i order was only $50 does anyone know where i might find the one i need ive bought 3 or 4 different ones and they all come in wrong i dont know what to do this flywheel has to exist!!
Snorbert is offline   Reply With Quote
Old 12-14-2008, 12:56 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
when i was doing this i got one from autozone for 90$ fits and works fine goto autozone.com search for "107"
Old 12-15-2008, 05:51 PM   #3 (permalink)
the 107 doen't fit it is only 11" in diameter mine needs a 12" i don't really know why im having so much problems but mine is a japan model if that makes a difference.
Old 12-15-2008, 06:03 PM   #4 (permalink)
View GregElliott's Photo Gallery
whats your VIN? or if you prefer, what engine, trans, options, trim package do you have?
GregElliott is offline   Reply With Quote
Old 12-15-2008, 07:53 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
well all the gen2 camry were built in japan. well what transmission do you have ? i converted my auto A140L to 5spd S54 transmission and that was the exact flywheel i used. and i didn't run into any problems.. for fun i just went to the garage and measured the 8 bolt crank flywheel i got and it's also 12" in diameter from teeth to teeth... so i'm sure the one i have on my car is also 12" since they both look exactly the same cep for the bolt holes... where are you getting the 11" from ?? i'm sure that one will fit and work
Old 12-15-2008, 10:11 PM   #6 (permalink)
my camry was built in Georgetown, KY.... or at least assembled there.
Old 12-16-2008, 06:47 AM   #7 (permalink)
i went to autozone and o'reilly and both the 107s where only 11" and it wont work cuz the disc that fits it is 7 1/2" mine is 8 7/8 i have the 3sfe engine
Old 12-16-2008, 12:32 PM   #8 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
There are only two different flywheels for the 3s-fe, like Atobe said. One with 6-bolts for the crank, one with 8. The center bore, pressure plate mounting holes and offset, etc. are all the same.
If you have a larger clutch than the flywheels you have gotten, you recieved a V6/3s-gte clutch disk and pressure plate.
-Charlie
Old 12-16-2008, 05:43 PM   #9 (permalink)
i have checked over this several times over i have a clutch disc that is 8 7/8 which is what shows for the 88 camry 4 cyl but the 107 that everyone says should work doent it is only 11" could it just be where i live or something or maybe a bad batch of flywheels cuz every flywheel i have found acutually in this model camry has a 12" but i can only find the 8 bolt and mine is 6 should i try to order the 107 off the internet? or just keep trying to reorder them at the auto parts stores?
Old 12-16-2008, 05:48 PM   #10 (permalink)
just to clear it up i am measuring from teeth to teeth and on the one i have with 8 holes it is 12" on the auto trans *which is blown* it is 12" the 107 i got from autozone and oreilly measures 11" would it matter that i bought the fenco flywheel fw9107 which is new instead of the reman 107?
Old 12-16-2008, 07:54 PM   #11 (permalink)
white90dx's Avatar
Kragen (partsamerica) lists the 2WD flywheel as 108 on their website... maybe try again?
-Charlie
Edit: The 108 is for the 8-bolt crank... nevermind...
Old 12-16-2008, 07:56 PM   #12 (permalink)
Pochacco Owns Me
atobe's Avatar
that's very interesting.. how about you try to get autozone to send a new 107 to your local shop and you pick it up and see... that's very weird that's the exact flywheel i used in my tranny. fenco sounds familiar too i don't have the box anymore but that's probbly the one i used. it was new w/o any core charge though and it was around 90$.. may be you'r just getting wrong parts
Old 12-17-2008, 05:09 PM   #13 (permalink)
USA
i went up last night and ordered the 107 it should be in tomorrow i hope it comes in right. the fenco flywheel fw9107 is only 61.99 and the 107 is 59.99 + 40.00 core if you payed about 90 it had to be the standard 107 but they should be the same...dont understand why they wouldn't my autozone doesn't deliver parts to shops i will be back to let you guys know if it comes in right if it does i think im going to e-mail fenco.
