camry wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2008, 04:03 PM   #1 (permalink)
drivin a 91' camry
View Avinator's Photo Gallery
camry wont start
please help my 91 camry still actin gay...it wont start, while i turn the ignition there is only one click and a small humming sound under the hood. My battery is good and everything is fine except that it wont start once in a while....any ideas?
thanks
Avinator is offline   Reply With Quote
Old 12-17-2008, 05:35 PM   #2 (permalink)
View GregElliott's Photo Gallery
if it's a manual transmission, replace the starter relay and/or clutch start switch... if it's an automatic replace the neutral start switch and/or you might just need a new starter.
Also, check the fusible link.
GregElliott is offline   Reply With Quote
Old 12-17-2008, 06:27 PM   #3 (permalink)
drivin a 91' camry
so far i would like to thanks for the replys and would like to add another issue about my camry....yes it is an automatic and the issue is that i have noticed that sometimes in the dashboard the PARK and REAR would occasionally light up when my car wont start...is this a sign on something? i will try to check on cleaning the neutral safety switch or maybe even replacing it if it solves the problem......thanks
Old 12-17-2008, 07:05 PM   #4 (permalink)
drivin a 91' camry
also my P R and N lights do not light up when i put my transmission in them
Old 12-17-2008, 07:20 PM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The selector position indicator lights are part of separate circuit, not part of start circuit.
Out of alignment neutral start switch will cause 'dead starter" no clicking.
Single click of the starter solenois without starter spinning caused by
-bad [large fat] cable from battery to bolt on starter solenoid connector
-starter solenoid contactsand /or plunger
-deterioration of the ground cable from tranny to negative battery post.
Doctor J is offline   Reply With Quote
