Fan won't turn off ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2008, 08:36 AM   #1 (permalink)
View drjpb's Photo Gallery
I have a 1988 Camry 3.5 V6. A couple of days ago I turned on the ignition and the main cooling fan turned on. I started the car and drove it thinking it would turn off. It stays on constantly. Is there a switch or sensor that I need to check or replace? Can someone tell me where it is and what it is called? Is it a factory part? Thanks.
drjpb is offline   Reply With Quote
Old 12-18-2008, 08:55 AM   #2 (permalink)
just a nobody
88 Camry with a 3.5L V6? 2.5L V6 maybe?
The coolant fan switch, I think it is somewhere around the thermostat housing in front of the engine or on the radiator, either one of the two, can't remember for sure.
N.E.O.
Old 12-18-2008, 09:33 AM   #3 (permalink)
Oops, sorry 2.5 V6
Old 12-18-2008, 12:08 PM   #4 (permalink)
View toyomoho's Photo Gallery
Are one or two fans on and if so, left, right or both?
Old 12-18-2008, 12:44 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
or a broken fan relay
Old 12-18-2008, 02:19 PM   #6 (permalink)
Standing in front of the car it would be the fan on the right, nearest the battery.
Old 12-18-2008, 02:42 PM   #7 (permalink)
Is there a way to check the relay before I go out and buy one?
Old 12-18-2008, 03:27 PM   #8 (permalink)
Does the car have AC, this might be the AC fan. Is the AC on?
Typically the fans are connected to a coolant sensor on the radiator or coolant manifold coming out of the head. They are typically wired so that a disconnected wire will turn them on. Check the wiring, make sure a wiring plug has not come off.
The relays would be in a plastic box, engine compartment.
You can test each relay using an ohm meter, see link below:
http://www.autoshop101.com/forms/hweb2.pdf
The link below has the wiring diagram, click on Figure 25.
http://www.autozone.com/addVehicleId...00c152801cce2c
Old 12-18-2008, 10:55 PM   #9 (permalink)
View Alex_K's Photo Gallery
Right fan is extra one as i know. If its not a problem with wiring plug,maybe radiator is too old? =) by the way thermostat is weak place of cooling system.
Alex_K is offline   Reply With Quote
Old 12-19-2008, 03:04 PM   #10 (permalink)
Gameroom cash: $302555
See if there is another identical relay in the relay box for some non-esential item. If there is, swap the two as a test.
Mike
Old 12-22-2008, 01:31 PM   #11 (permalink)
Thanks for the comments. It was the fan relay. Works fine now !.
