If it's like the generation 3 switches, (not really sure) just pull the boot up from the bottom. That should expose 1 10MM hex head bolt. Remove the bolt and pull out the switch just enough to see the back side of the switch. Don't remove it from the car if you don't have to. If the wiring drops inside the door you will have to disassemble the door to retrieve it. Chances are the back side of the switch is all rusty. If it is, clean everything with a wire brush and apply some dielectric grease on everything back there to prevent rust from forming again. Also clean the bolt of all rust. It acts to ground the switch to the frame of the car. Do all 4 switches. See if this helps with the problem. If not, you will have to do a dark current draw test.
Mike
