insturmnet lights 1991 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2008, 11:13 AM   #1 (permalink)
View bill67's Photo Gallery
just purchased insturment lights working when I drove it home, lights quit working 2 days later, noticed tail light fuse blown, replaced still no lights, only thing I have done is install new radio. Any thoughts or wiring harness available so I can bypass dimmer switch which cost $126.00 and don't know if that is the problem. Thanks
bill67 is offline   Reply With Quote
Old 12-27-2008, 12:10 PM   #2 (permalink)
View toyomoho's Photo Gallery
Do the tail lights now work? All lights work such as the cig lighter, defogger switch, etc but not the console lights.
Have you checked Gauge fuse?
The AutoZone website at www.autozone.com has wiring diagrams.
Old 12-27-2008, 02:40 PM   #3 (permalink)
tail lights
tails work, glove box light comes on when you turn on the parking lights, no other lights come on defoger, cig or as tray. cig lighter does work, all lights like clock and gear light do get dimmer
Old 12-27-2008, 02:41 PM   #4 (permalink)
did check all fuses they are ok did not see gauge fuse
Old 12-27-2008, 03:33 PM   #5 (permalink)
The following lights are supposed to be on the same circuit and connected in parallel.
Cig, combo meter, radio, defog, A/T indicator, hazard switch, cruise, autotrans shift pattern selector, O/D,
Parallel means each light is connected between the power source buss and dimmer buss. The dimmer is connected between the dimmer buss and ground.
Power runs to one buss, through the bulbs and to the other. Then through the dimmer and ground. One wire from each bulb is connected to each buss.
In reality these busses could be just areas where the wires are grouped together or a junction box.
If any bulbs are working the Tail fuse is OK. If any of the lights dim, the rheostat is OK.
You might have an issue with the bulbs themselves or the wiring to them.
Old 12-27-2008, 07:22 PM   #6 (permalink)
View joeykrim's Photo Gallery
If I read that right, the dimmer switch which costs $126.00 on my car broke and I grabbed one out of a junk yard car, $5. It was about 2 years ago and its still running great.
joeykrim is offline   Reply With Quote
