you want to "scrape" the old HG away? are you wanting to do a replacement? or fix the above mentioned issue? the "issue" above is common with our age cars, and newer too, if you want to do the head gasket, you'll want to get the head machined, pressure tested, etc. and just doing the gasket would be a waste, you'd need to do the Valve Stem Seals, and other seals, and gaskets too. not a simple "i'll do it this weekend" task. confer with your local mechanic about it. we can all give you info, and pics, but the face to face contact will solve a lot of the ambiguities of the conversation.
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
