Hi..
I searched your archives about no brake lights on my GF's 91 Camry and found an article that was some what helpful to me as a person that doesnt work on cars but does have some common sense, but I thought that if I gave a little more info that maybe someone could help me get closer to the solution.
I got a lot of info from
drugal who wrote this post:
No brake light
I am hoping that with some more info someone could help me get closer to the solution. Heres some observations I made after reading that post:
1) All lights in the rear work
except the brake lights. The tail, turn signal, side markers, and the license plate lights are working.
2) I did a visual inspection of the wire harnesses and wires that move with the trunk lid, also I followed all visable wiring in the trunk. No splices or obvious repairs seem to have been made. All seems to be in great condition.
3) About 1 year ago when my GF bought the car, the brake lights didnt work. The owner said he thought that it was the brake switch so I replaced it and the lights have worked for the last year till now. I did a visual inspection on the switch and checked the nut that holds it in place was still tight, checked that the switch engaged at the proper time, and also listened for the switch to engage and disengage when the pedal was pressed and let go. All seems to be working in properly, and the visual inspection was good.
4) For the last 2 weeks we noticed that the rear lamp warning indicator on the dash board has been flickering at times.
With this info, can the possible trouble areas be narrowed down?
Thanks for any help possible. If we were in a situation where we could just put it in the shop and not worry to much about the cost, we would, but were not.
