Power steering belt broke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2009, 05:21 PM   #1 (permalink)
View BHSmout's Photo Gallery
Hi All,
Its absolutely frigid here on the prairies. I warmed up my 1990 V6 Camry and headed out. Hmmm, the steering is really frozen up, I thought. I checked the power steering fluid level and it was ok. I got home and found a broken belt in my parking spot.
Will I damage the vehicle if I drive the car until I can get it to the tech?
Other than heavy steering there seems to be no other problem.
Thanks,
Brian
BHSmout is offline   Reply With Quote
Old 01-03-2009, 05:40 PM   #2 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
I dont think you will do any damage with having a broken belt. But isnt that the really tiny belt thats impossible to get to ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 01-03-2009, 09:31 PM   #3 (permalink)
View toyomoho's Photo Gallery
Should be OK without PS.
Bring the old belt with you when you get a replacement to compare.
Make sure it was worn belt and not a frozen PS pump.
Old 01-04-2009, 01:18 AM   #4 (permalink)
Thanks for the tips. I'll bring the belt with me to the shop. I hope it was a worn belt but I have had a "burnt rubber" smell coming from under the hood for about a week now. Maybe the PS pump has packed it in and that's why the belt broke.
Wait and see I guess.
Old 01-04-2009, 02:08 AM   #5 (permalink)
just a nobody
If you are going to operate the vehicle without the power steering belt, you might want to suck out some of the P/S fluid, otherwise, the fluid might get push back into the reservoir when you turn the rack, and overflow.
N.E.O.
Old 01-04-2009, 12:07 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
run atf in it, ps oil is pretty thick when its cold
Old 01-05-2009, 05:44 PM   #7 (permalink)
disregard's Avatar
Which would explain the loud whining noises the PS pump makes when the engine is started cold.
On very cold mornings I mean
Old 01-06-2009, 03:44 AM   #8 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
It makes that whining noise if the fluid is low, regardless of fluid type. It could also be it slipping when cold?
Jimnist is offline   Reply With Quote
Old 01-07-2009, 02:05 PM   #9 (permalink)
disregard's Avatar
yeah on very cold starts like under 30Farenhiet it slips for the first 2 minutes after that its fine. Fluid is full but its got the thick stuff in it, regular power steering fluid, not ATF.I think it should be running ATF.
