Slow Acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2009, 10:32 PM   #1 (permalink)
drivin a 91' camry
View Avinator's Photo Gallery
Slow Acceleration
Hi i am seeking for help/solution to a problem with my Auto 91 Camry. Sometimes when accelerating from zero it moves like a turtle even when i hit the gas pedal real hard. It has to reach 25mph to start speeding up, so what i do to speed up from the start is that i put it on the lowest gear, (3) and hit the gas. PLease i need to know what the problem is and if anyone can help.
Thanks
Avinator is offline   Reply With Quote
Old 01-08-2009, 09:22 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
if engine revs up but car moves slowly, check the transmission [fluid level]
If engine lacks power at acceleration, "hit" the gas pedal in P or N; if engine responded with delay
check for
trouble codes
spark plugs
vacuum leaks
fuel mixture [possible lean]
if engine lacks power under load check ignition timing and ignition coil.
Doctor J is offline   Reply With Quote
Old 01-08-2009, 11:06 AM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
are you sure it is starting out in first gear?
Old 01-08-2009, 01:27 PM   #4 (permalink)
Gameroom cash: $302555
"i put it on the lowest gear, (3)"
1 or L would be the lowest gear. 3 is 3rd gear.
Mike
Old 01-08-2009, 03:26 PM   #5 (permalink)
View kesando's Photo Gallery
Isnt "3" Drive with OD off? Perhaps you mean "2".?
A single guy with two Family Sedans
kesando is offline   Reply With Quote
Old 01-08-2009, 03:46 PM   #6 (permalink)
drivin a 91' camry
sorry its the "L" gear and engine revs up its just the car moves slow and tranny fluid is good and engine revs pronto at P and N. i dont know what vacuum leak is
Old 01-08-2009, 08:29 PM   #7 (permalink)
"engine revs up its just the car moves slow and tranny fluid is good and engine revs pronto at P and N."
That sounds like a transmission problem. How many miles are on the car and what type of transmission maintenance has been done over the years?
Mike
