A 3SFE Story with a happy ending! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2009, 07:01 PM   #1 (permalink)
View lionheart03's Photo Gallery
As some of you may recall, my first post was on here a few months ago, when I discovered my engine problem was the complete loss of compression on #3 cylinder.
I'm an electrician by trade, and a rather mechanically included person all around, but I had no experience with auto engine repair, such has dealing with a bad valve. With some help of a friend and his well equipped and heated shop, I was able to tear my motor down and find the problem. A burnt exhaust valve!
Since I had the engine torn down this far, I decided to fix the many oil leaks it had. The main seal, cam seal, oil pump gasket & seal, and distributor seals had all been leaking oil. The oil pump gasket was the big problem, it had deteriorated to the point that I was loosing a quart oil in with a tank of gas.
Since the water pump is driven by the timing belt, it too was replaced. I had the timing belt and components replaced a few months ago, and it seemed good, with no oil on the belt despite all of the leaks.
Once everything was back together, the car was running great despite a few leaks I had to go back and fix. The second time around the engine was running, but had no power. I was one notch off on the timing. Fixed that, and all that was left was to adjust the ignition timing. I got the distributor set to as close to 10 BTDC that I could. Car runs great with decent power. Plan on driving it a bit, then changing the oil again soon.
Anyways, thanks to everyone who replied to my post! Hopefully I kept another 91 Camry on the road. The total cost: around $520 in parts, with some labor to the machine shop that rebuilt the head.
lionheart03 is offline   Reply With Quote
Old 01-12-2009, 05:32 PM   #2 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
Glad to hear it ! You now have a strong runner on the roads again ! But I'm still surprised to see you had a burnt valve at only 170,000 miles. Was that mileage correct ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 01-12-2009, 06:32 PM   #3 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Exelent, glad to hear you're back on the road with it and it's running good.
I always stop for gas in Corydon with our company Tacoma. From Georgetown to Corydon is almost a full tank of gas when pulling a trailer.
BTW: That valve looks more like a break than a burn.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
