Cooling Fan Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2009, 12:23 PM   #1 (permalink)
View AcIdBuRn02ZTS's Photo Gallery
2nd Generation Cooling Fan Issue
Hey alls...
I have a problem that when I turn on the ignition, both cooling fans kick on and stay on untill i turn the key back off... doesnt matter if i start the car or not... the car takes forever to warm up on the cold mornings because of this...
i did a few searches but couldnt find anything..
any ideas?
thanks
-AcId-
AcIdBuRn02ZTS is offline   Reply With Quote
Old 01-13-2009, 02:42 PM   #2 (permalink)
Gameroom cash: $302555
Just a hunch. Locate the cooling fan relay. It's probably located in the engine compartment under the hood in a black box marked fuses and relays. Tap the cooling fan relay and see if the fans stop running. If not, try to switch the relay with an identical relay from another non-esential item in that relay box and see if that helps. If either of these tests solve the problem, you know you need a new relay.
Mike
Old 01-13-2009, 05:28 PM   #3 (permalink)
i replaced the relays w/ junkyard relays a few days ago and it didnt make any difference... but i'll check
thanks
-AcId-
Old 01-13-2009, 06:15 PM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Is your Camry a V6 or I4? This is a common problem on the V6 models (not sure about the 4-bangers), so it's entirely possible that the scrap yard relay is no good.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 01-14-2009, 09:27 PM   #5 (permalink)
its the 3sf3 4 popper
-AcId-
Old 01-16-2009, 12:34 PM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Take the wire from fan sensor switch and connect it to the engine ground with jumper.
Turn ignition on
If fans are running now, the high pressure switch in a/c system is stuck closed, if fans are not running, replace the fans' sensor switch.
Doctor J is offline   Reply With Quote
