1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
Good advice, Malayan. As for the jiggle pin, most good aftermarket thermostats are made with a jiggle pin (this must be at the top of the t-stat when you put it in). Only the cheapest of aftermarket t-stats are made without the jiggle pin...
__________________ 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
Wow! I learn more and more each time I come to this site...
Thanks TBoy I must call my auto parts account and ask them why they sell cheap aftermarkets.
The T stat is one of the most important parts that should be high quality because it determines if your engine stays cool.
I am sure the couple extra bucks it would cost for a quality one would be worth it.
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
No problem, always glad to share info guys. As for the jiggle pin, I'm wondering if you can get the MotoRad brand at your parts stores in the States? It's a relatively inexpensive brand (I've bought them from NAPA and also from Canadian Tire/PartSource here in canada) and all of their t-stats are made with jiggle pins. They're way cheaper than OEM, and for a few extra bucks they come with the "failsafe" feature which ensures the t-stat never fails closed (as happened to my first Corolla and almost warped the head).
Ask your parts guys to check the units before they sell them to you--usually the packaging is either transparent or it's a box. Either way you can eye the unit to ensure there is a pin.
Yes! They are right too...
I put a funnell in the cap hole and put electical tape around the tip till I have a tight seal....Then...... Put coolant into the funnell half way up...Then let it idle and the radiator will burp and pull any coolant needed out of funnell....
keep funnell half full till operating temp...
done this about 4 times now on cust cars...Works great and beats buying a purge tank sytem tool...
they make a funnel that fits on the neck of many radiators and it works great for working air out of the system, but theyre pretty pricey.. before i got mine, a cv boot would also fit in most import radiator necks too, makes an awesome funnel!
The Following User Says Thank You to hondamatic For This Useful Post:
Yes, usually you can catch them on sale. The going rate for these on the tool trucks these days usually run 19.95.
Another way to burp the system is to also keep the front of the car on an incline or raised only in the front.
__________________ 2000 4Runner 3RZFE 5speed PT70 Built Supra 600hp behind us now 1991 2vzfe Camry Le loaded 1995 Corolla DX sunroof (Totalled ) 2004 TRD Tundra V8 (sold)
You can also give the main line from the radiator to the engine a squeeze once it is up to operating temperature. Sometimes a little air gets trapped in that line where it bends and you will want to get it all out.
Leave the cap off the radiator when doing this and keep a few paper towels handy in case of overflow that the catch tank isn't able to take.
Mine took about 15 minutes to purge all the air after getting up to operating temps. It is boring but you will thank yourself later when your car runs correctly.
I must be the only person that just fills it, starts the car, squeezes the hoses to get the easy bubbles out.... then puts the cap back on with some extra fluid in the overflow and just drives the car.
A bit of air at the top of the radiator won't cause any problems, and you can easily go back and fill the rest if necessary over the next day or two.
If this were an MR2, I'd feel differently.
-Charlie
