Creaking Noise on my 91 Camry DX!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2009, 12:16 PM   #1 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
I need help to diagnose my creaking noise coming from my drivers front wheel. It'll happen when my car bounce up and down or when the body roll to the right. It'll still make the noise even if i'm just driving it with little bumps and such. Anybody have this problem?
Either it's the:
-Sway bar end link/bushings
-lower ball joint
-upper ball joint
-lower control arm bushing
Need help!! It's sorta annoying.
204whp/157wtq
Nusdogg is offline   Reply With Quote
Old 01-29-2009, 12:48 PM   #2 (permalink)
View toyomoho's Photo Gallery
Would start with the sway bar bushings, These are also cheap and easy to replace.
Old 01-29-2009, 02:28 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
It is most likely the swaybar 'endlink' bushing - ie, where the swaybar goes through the control arm. You can buy a pair of loaded control arms (bushings and ball joints) for cheap on ebay. Those should solve your problem.
-Charlie
Old 01-29-2009, 08:04 PM   #4 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
How to troubleshoot squeek in front end
Last time had this problem i went around and sprayed silicone lube on one bushing at a time then I would bounce the front end by hand when the noise went away i found the culprit.
6-10 times it was the swaybar bushing going through the LCArm.
hey are easier than you think to replace so I just put the whole arm in $90 each on ebay or about $20 from the yard... Some times hard to find used without same prob.
malayan is offline   Reply With Quote
