Pod filer causing problems for anyone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2009, 06:36 AM   #1 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
I encountered a problem today and i think it might be because of the pod filter. I noticed that when you quickly open the throttle (quck cracks with your wrist) several times, it would start to idle funny and then start to struggling to idle. At this point opening throttle did not raise the rpm, not even WOT. I didn't leave it long enough for it to stall out, but when the revs dipped down to about 500rpm the engine check light would turn on and then turn off when it raised. This has happened only once - today; it's usually driven gently with care but today my 'friend' was pushing it pretty hard.
He said it was slightly hesitating when you initially open the throttle.
My auto teacher thought that it was because of the pod filter allowing enough air that the AFM can't keep up on initial surges of air, which is why it was hesitating.
What's everyone's thoughts? Has this happened to anyone else?
Jimnist is offline   Reply With Quote
Old 02-03-2009, 12:28 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
what code is in it?
Old 02-03-2009, 01:30 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Its not the air filter... it is probably something else.
-Charlie
Old 02-03-2009, 02:59 PM   #4 (permalink)
セクシーの定義
Originally Posted by fredk View Post
what code is in it?
Umm.....i don't know
I'll test today. Thanks.
Old 02-03-2009, 03:50 PM   #5 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
Your auto teacher sounds clueless. Unless there is a blockage of airflow due to the filter, or too much air being forced (which i dont think would make a difference) then the filter wouldnt do a damn thing. I believe that the stock filter is better anyway is it not?
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 02-03-2009, 10:11 PM   #6 (permalink)
セクシーの定義
I did a diag test and i don't think it pull any codes, it was flashing constantly with no pauses, so i assume it was 8 consecutive over and over again. Took it for a little drive today and it was fine.
What do you think is causing the Charlie?
What's your reasoning behind this conclusion?
Old 02-04-2009, 02:10 AM   #7 (permalink)
white90dx's Avatar
If the CEL is constantly flashing in .5 second increments, that means no codes. I'm also not aware of a mode of the 3s-fe ECU that would flash the CEL for any reason other than to check the codes. Maybe there is a short that puts the ECU in diagnostic mode? This would also mess with the timing and possibly cause the running like you describe.
-Charlie
Old 02-04-2009, 07:44 AM   #8 (permalink)
日産自動車パワー!
JMSports's Avatar
Ive heard from other members that the stock airbox is the best option for this motor.
Old 02-04-2009, 03:10 PM   #9 (permalink)
セクシーの定義
-Charlie
When you say this, are you referring to when the check light came on whenever the revs dipped down to 500rpm and then turn back off when it raised a little bit?
Have any vague ideas as to where the short could possibly be?
Old 02-05-2009, 03:38 AM   #10 (permalink)
View kesando's Photo Gallery
Ive heard a couple of people on this board reccomend K&N drop in filters for this motor as a good upgrade for the 3SFE. Is it really worth it? What differences does it make? Mabey you should switch back to stock box with K&N.
A single guy with two Family Sedans
kesando is offline   Reply With Quote
Old 02-07-2009, 01:36 AM   #11 (permalink)
the gen 2
blkdmnrcing's Avatar
View blkdmnrcing's Photo Gallery
charlie, correct me if im wrong, but if the car is getting down to 500 rpm or so, wont the check engine light pop on because the car is about to stall and is just reading the key in on position????? i have a pod filter on my car for 2 years now, has always run great, and never had a bit of problems with it.
89 Camry I4 5-Speed - JDM Head, Turbo'd! Now needs Exhaust and Tune!!
93 Paseo I4 Automatic - Daily Driver
look out, ed wants to drop kick spiderman!!
blkdmnrcing is offline   Reply With Quote
Old 02-07-2009, 08:03 AM   #12 (permalink)
セクシーの定義
I guess i've got some gremlin in my car somewhere. I'll try cleaning the throttle body, ISC valve and EGR sometime and see how it goes.
Thanks for everyone's input.
