91 camry le power stearing leaking bad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2009, 07:09 PM   #1 (permalink)
View god and me's Photo Gallery
it only leaks when parked after a drive
the camry has 125k
and the tranny vibrates after shifts and its a auto
will a fluid change help the tranny thing
we just got the car
as a back up car and it was never cared for
thanks
god and me is offline   Reply With Quote
Old 02-03-2009, 07:14 PM   #2 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
is this a V6 or 4cylinder ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 02-03-2009, 07:33 PM   #3 (permalink)
4 cylinder
Old 02-04-2009, 10:02 AM   #4 (permalink)
I need some help on this one
AS I'M NEW TO THE TOYOTA WORLD
Old 02-04-2009, 10:38 AM   #5 (permalink)
View nuron's Photo Gallery
There are many many past threads on the P/S leaking, as this is a common problem with the Gen 2 Camrys. I don't know what the vibration after shifts mean but it couldn't hurt to give it a change of fluid. Could be your mounts that are just too old. When you put the engine in D, R, or P, does the whole engine move under the hood?
nuron is offline   Reply With Quote
Old 02-04-2009, 11:50 AM   #6 (permalink)
no I think the mounts are ok its in the tranny
it has to much in it and it has a bad smell and dark
so I think its time
can i do it my self
Old 02-04-2009, 02:05 PM   #7 (permalink)
Gameroom cash: $302555
"it has to much in it"
What do you mean buy this? If you mean it is overfilled, then take the car for a ride so it's warm and then recheck the the trans fluid. It should be near the full hot line. If it is over that line, drain some fluid out till it sits at the full line. You will need a 10MM alan wrench to loosen the bolt underneath the trans pan. Make sure you are checking the trans fluid with the car running. This is the opposite of how you check the engine oil. After draining some fluid out, take the car for a test ride to see if there is any imporvement.
Mike
Old 02-05-2009, 03:22 AM   #8 (permalink)
Ramsey's Avatar
View Ramsey's Photo Gallery
Hey i have a gen 2 camry and my power steering was leaking fairly bad then later found out it was the p/s pump got it replaced and has never leaked since.
Ramsey is offline   Reply With Quote
Old 02-05-2009, 06:03 AM   #9 (permalink)
ok then will try that
Old 02-06-2009, 03:07 PM   #10 (permalink)
Justin727's Avatar
View Justin727's Photo Gallery
might also be the rack and pinion aka the steering gear. Mine is currently leaking pretty badly and needs to be replaced. Luckily for me trans fluid comes free so it can wait till I do all the other preventive maintenance.
Justin727 is offline   Reply With Quote
