brake light/shift lock issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2009, 12:16 AM   #1 (permalink)
View BugDiddy's Photo Gallery
so 2 days ago i find out my brake lights dont work (tails do though). I narrow it down to the lamp out sensor which i discovered had fried part of itself. I soldered it back together and they worked good again
today however, after i started my car and hit the brakes to get into reverse, the headlights dimmed a lot, and then i noticed that the shift lock wasnt being released when i pushed the brake pedal. also brake lights are now gone again
the lamp out box looks ok still
15a brake fuse is still good
bulbs are good
so im guessing it might be something with the brake switch? that would be the only thing that would cause it the shift lock to cease functioning right? or maybe there is something im missing?
BugDiddy is offline   Reply With Quote
Old 02-11-2009, 12:43 AM   #2 (permalink)
just a nobody
Use a test light to make sure you have power going to and coming from the brake light switch!
N.E.O.
Old 02-11-2009, 12:51 AM   #3 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
I bought a Camry that had the tail sensor burned out like you describe. The previous owner had tried replacing it and burned out the second one. They also had started to pull apart wiring harnesses looking for the short that was causing them to burn out. As it turns out the reason the lights out sensor box was shorting out was because someone had replaced one of the rear taillight bulbs with the wrong type. They had put a single filament bulb where there should have been one of the dual filament ones. The single contact at the base was shorting out on the dual contact in the socket.
First, check all your bulbs to verify they are correct type for the socket they are in, then you will need to track down what in the circuit blew this time, you may still need to fix or replace the lights out module.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
