Need help For Headlight Buzzer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2009, 02:01 AM   #1 (permalink)
View heat_z0ne's Photo Gallery
i have 91 camry 4 cyl
this model has no headlight buzzer feature , if u keep ur headlight on after turning ur car off.
I want to connect buzzer ,so when my car's headlight is on & when i open door i will hear BEEP
Please help to find cable & cable color so i can install buzzer to save my battery
Or if u have any idea PL Let me know
I search all thread but i could n't find solution
Thanks in advance
From brother hood
heat_z0ne is offline   Reply With Quote
Old 02-20-2009, 05:20 AM   #2 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
2nd Generation Headlight Buzzer / Bell
This is how to wire a bell or buzzer to remind you that you left the headlights on when the door is opened. Headlight bell or Headlight Buzzer.
Answer
The headlight on buzzer must be wired to the door switch as well as the lighting system. It is not necassary to wire it to the headlights as the park light will be illumintaed at the same time .
The door switches are linked to the interior light and provide an earth(-ground) when the door is opened,
Look on your fuse cover and locate the park lamp fuse. Using a connector take a lead from the fused side of the supply (remove the fuse while the lights are on and one side of the contacts will lose power)
You need to connect to that one. Run this to where you are going to secure or locate the buzzer. Connect this to one side of the buzzer.
Depending on what type you are using it may be critical to get the positive and negative connection correct. So place the supply from the fuse box to the positive side.
You could leave the fuse out while doing the job in case you leave the lights on and create a short circuit while working with the wires.
Trace the wire from the door switch and connect a second wire to this and run it to the other connection on the buzzer. Refit the fuse and test the circuit.
Now... to find you a buzzer..... Go here http://shop.ebay.com/items/headlight..._dmd=1&_sop=12
Hope this helps!
Don www.aoktoyota.com
malayan is offline   Reply With Quote
