its a fuse mos def. I had the same problem when i installed a new cd player. The fusebox I believe is to the left of the steering wheel, or where your left knee would usually be. Pull out the cover and get your driver's manual. It'll tell you what each fuse does. The clock, stereo, and dome lights could be using the same fuse, or maybe you have you have 2 fuses which have burnt. It's an easy fix so don't sweat it.
cheers
Vik
Gen2 FTMFW
