Hard start, miss at idle, miss during accelration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2009, 07:13 PM   #1 (permalink)
toyoman13's Avatar
View toyoman13's Photo Gallery
2nd Generation Hard start, miss at idle, miss during accelration
I have a 90 camry wagon I4 with 336,000 miles on it go yota. My problem is I was leaving work got in my car started it put in reverse was pulling out then it just died. I try to start it but all it would do is just turn over, sputter then died. Towed it home the spark plugs were kind of nasty so I changed them along with wires, cap and rotor.That got it running again but now when I start it i have to put my foot to the floor or else it will just turn over. Then once I get it started it idles rough. After it warms up it will miss at idle sometimes and it miss under accelration but only form a stop for about the first 1500 rpms and then it runs fine. Sometimes it get so bad that I have put my foot to the floor just to get it above 1500 rpms. I though maybe the timing was off I check it and I got it right but it still does it and I had to turn the distributor all the just to get in time. I don't think that is normal. If you guys can help that would be great.
toyoman13 is offline   Reply With Quote
Old 02-22-2009, 07:17 PM   #2 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
What about the Ignition coil ? Was that ever replaced ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 02-22-2009, 07:46 PM   #3 (permalink)
toyoman13's Avatar
I replaced it about six month ago.
Old 02-22-2009, 10:57 PM   #4 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Sounds like you're running rich (hence why you have to floor it). Maybe the AFM is stuffed? IAC valve clean and working? EGR fine (not stuck open or clogged)?
Jimnist is offline   Reply With Quote
Old 02-22-2009, 11:39 PM   #5 (permalink)
View igonuts2's Photo Gallery
could be a worn timming belt that slipped? set up crank at TDC (compression stroke), pull cover to insure the cam is where it should be. even if it's not your issue, it's easy to check. just trying to give you more food for thought.
92 pu 4x4 V6 5sp 3'' lift
89 tercel 3dr 3e 5sp
'56 willys pu 4x4 "rat". under destruction. i'm in heaven!!!!!!!
igonuts2 is offline   Reply With Quote
Old 02-23-2009, 06:28 AM   #6 (permalink)
toyoman13's Avatar
thanks guys I will try checking these things and get back to you.
Old 02-23-2009, 01:57 PM   #7 (permalink)
viktord1's Avatar
View viktord1's Photo Gallery
I'm no expert but I think it could be an oxygen sensor. My buddy replaced it on his mustang and it idled superb and ran better at low speeds.
Vik
Gen2 FTMFW
viktord1 is offline   Reply With Quote
Old 03-12-2009, 08:25 PM   #8 (permalink)
toyoman13's Avatar
Sorry it took so long i check all those things out they were fine. So I look to see if they were many codes in the ecu. There was a code 12 no ne, g signal to ecu. Took a look that the distributor and there was oil leaking into it. Replace the distributor b/c the seal failed and the coil i put in 6 month ago already had a crack in it. Car runs fine now. thanks for the help.
Old 03-12-2009, 10:19 PM   #9 (permalink)
mk2-1jz's Avatar
View mk2-1jz's Photo Gallery
edit
Build Thread: http://forums.celicasupra.com/showthread.php?t=53215
~ Jamie - 1985 Supra - 1988 Camry
~ Supra, Its a Religion
mk2-1jz is offline   Reply With Quote
