Need help; running out of ideas
My '90 Camry Dx has a 3SF-E, and has been having problems. Upon warming up, it begins to idle really rough, quickly getting to the point of stalling when I come to a stop. The problem only really exists at lower RPMs. Once this problem happens and I turn it off (or it does that on it's own), it's very hard to get it to restart until it's cooled down quite a bit. It will turn over for a second or two, and it'll only stay on if I rev it up really quick. A lot of the time, I don't even have enough time to even do that before it stalls out again. Upon accelerating, there's an odd kinda clicking/clanking noise that speeds up with the engine, but only in a low RPM range.
I've put a new EGR sensor in it, checked the distributor cap and rotor (worn but runnable), put in new oil, air filter, fuel filter, thermostat (old one was stuck closed), spark plugs, battery, and ignition coil (the old coil was waaaaay cracked), and unplugged the O2 sensor and tried running it, all to no avail. Anyone have any ideas? I'm gonna try and get some codes from it tomorrow.
No Check Engine light or anything. And, according to the gauge on the dash, the temperature isn't running any higher than it should be. I'm gonna replace the distributor cap and rotor when my tax refund comes in, but I really don't think that's the problem.
