1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
I can't seem to locate a recommended change date for a 90 Camry, 4-cylinger engine. It was last done 4 yr ago at 63K, now at 118. My impression is every 60K but I was wondering if anyone knew more positively. It doesn't seem to be in the car manual or shop manual. Thanks!
I've been told to replace the water pump too while this is going on. Sound good if nothing has been a problem with it yet?
I've always been under the impression that you do it every 5 years or 100 000km's (average of 20k's a year), but i've noticed people are now changing the earlier, say 70k.
Yeah, do the water pump since you're working in that area and a new thermostat to go with.
I would personally replace the cam seals and crankshaft seal along with the water pump and thermostat at the same time with some fresh coolant. If you have been running green coolant stay with it. toyota didn't come out with the Red coolant till the early mid 90's I believe so our gen camry's ran from the factory green.
BUT if you want piece of mind flush the coolant correctly and then you can run Beautiful Toyota red coolant!
Thank you Mike. Guess I better get it done and the associated replacement parts as well. BTW, is the Camry the sort of engine that is destroyed whent the belt breaks or just stops.
Good luck
Or Toyota Pink
Jaansu
I believe that both 4,and the 6 cyl engines the second gen camrys is a non interfearence.
The 4 cylinder 3SFE engine is definitely a non-interference engine, so no damage will be done if the belt does break. However, as mentioned above, you will be stranded.
